1 - 11 of 11 Posts
Hey all I have a question that I'm not sure what is going on maybe someone could help me, when i take my bike out for a good ride at least to get hot after i park and shut it off i hear gurgling noises from front side of bike, has anyone heard this before, also when i lean on kickstand i also hear it, and i recently did the pair valve delete and removed all components and plugged airbox and installed blocking plates over pair valves. Its a 04 honda VTX1300C
No idea. Maybe check your coolant reservoir fill level. Coolant only thing I can think of that might gurgle.
Was it the coolant? Mine makes that same noise sometimes.
No it wasnt and i still dont know what it is, lol my coolant was still full and the reserve jug underneath was good so idk just hope its not something bad to cause a problem
From ID, GO VANDALS!
There are a numerous threads about this on here. It looks like the consensus is that it is the coolant bubbling in the cooling system.
Hope that helps.
Jeremy
Maybe it was your stomach :)
Sounds like there's air in the liquid cooling system.
When was the last change of coolant?
Did you / they "burp" the coolant system?
You can "burp" your bike. Make sure there's gas in your carburetor. Remove the tank. Remove that coolant lid. Start the bike and rev it up. Bubbles will come up the coolant system. Refill with coolant. Repeat procedure until there are no more bubbles. Check coolant level in reservoir under engine.
Good luck!
Great tip. Most folks think you cannot run a VTX1300 without the fuel tank in place but there is plenty of fuel in the carb float bowl to run the bike for about 1 to 1.5 miles or around 2-4 minutes - plenty of time to burp the coolant system.
To burp coolant system, I remove radiator cap then squeeze hose from the radiator to water pump numerous times until coolant is absent of air. Then top off with appropriate mixture, replace cap then test ride and watch temp and coolant reservoir. Wishing you well!🇺🇸🇺🇸
1 - 11 of 11 Posts
