1 - 12 of 12 Posts
When I did it. I removed the headlight bucket first to gain access to the mounting bracket. There are two bolts to remove. The headlight extension mounts where the headlight mounting bracket mounted. After the extension is mounted, attach the bucket mounting bracket to it. Attach the headlght to the mounting bracket. 10mm socket & 10 mm boxed end wrench does it all.
what they said, here's a shout out from Calgary Alberta - may you ride with the wind at your back, the sun overhead and the road endlessly winding.
Welcome to the Cafe from Spring, TeXas. :cheers:
Welcome abaord from SE Texas! :cheers:
Welcome to the cafe' from NC. Under forums, go to the 1300 forums. There is a red "sticky" for the manual. You can download a manual for your bike free of charge that will show where and what bolts need to be removed as well as follow the above directions.
.45 Goodness
Welcome from Frostproof,FL.:)
Ride Safe :choppersm
1 - 12 of 12 Posts
