1 - 8 of 8 Posts
Am i blind or does an 05 VTX not have a helmet lock on it? I swear i read somewhere that it did.
team VTX cafe physician
if it's there...look under your left bag.......attached to the frame......I have used gun locks...the kind with a short wire that locks in to the lock...works great around anything..good for jackets, too
yup, there is one under your left bag. On the T version there are two and the bags get in the way totally on the one and a bit on the front one. There are Helmet T's build for gold wings and I bought and you feed it through the D ring and then slip it into the lock so your helmet will fit. Here is an example. Look around as there are different styles.
http://www.davescyclesupply.com/product_details.php?category_id=43&item_id=245
I made a bracket to extent the helmet locks out past the bags to the front. By using the "T" bar that has been discussed, this will let the helmet lay on the passenger floorboard for support. I have included a picture from each side to get a better idea of the location. Hope this helps.:patriot:
1 - 8 of 8 Posts
