1 - 3 of 3 Posts
Hi friends,
I read but I do not find that there was a technique to properly reassemble the entire front of the VTX1800C, I redid the fork completely oil / spring / seal spy and I tackle the reassembly.
Thank you for the help
always google translation:D:D
Bernard
If your talking about reassembling the forks brakes etc back together reverse order from disassembly. Two issues to be concerned about. The alignment of the axle from the left fork to the right. With the forks installed the axle should push into the RH fork without raising the RH fork to make it fit. The adjustment nut under the left cap will adjust the level up or down for this alignment.
there is a machined ring on the axle. This ring should be flush with the I/D of the left fork for proper spacing. If not your left brake will drag.
that’s about it.
good luck
1 - 3 of 3 Posts
