HELP!! trying to do fork seals on 04 1300c seal is stuck. tried for over 3hr cant get lowers apart from upper tube???
Dragon Slayer
I take it you've gotten the drain bolt out from the very bottom of the fork tube assembly. There is a small "clip/retaining" ring that holds the seal in place, make sure that's out, to get the two assemblies apart, you have to basically keep pulling them apart with some considerable force to get the guide bushing out from the bottom assembly.
clips out bolts out using lower as a slide hammer 3hrs last nite seal has not moved thinking machine shop??
Dragon Slayer
If you spent that long & it still hasn't budged, machine shop might be the way to go. I know at first I wasn't sliding them apart as hard as I needed to, but got it after about 1/2hr.
