Ok then tighten the battery cables with a wrench or socket.
Check all the small wires going into the ICM on top of the battery the black one and green ones tend to break inside the insulation so look real close
next would be drain the float bowl on the carb there is a screw you can open and the fuel will come out of the post from the bottom of the bowl
