1 - 14 of 14 Posts
· Candy Black Cherry = FAST
Hey everyone,
I'am looking for a horizontal side mount license plate that does not cost an arm and a leg. I've seen some really cool ones, but they were around $200 to $300. I really don't want to spend that much for it, Gotta save some for more chrome, you know. Any suggestions would be great ! Thanks, Caroline
I had the same problem also. I didn't want to spend that much to clean up the rear of my bike. I came across a triple chromed licence plate holder with white led illumination at Walmart (couldn't believe it!) for 40 bucks. I unbolted the factory light and black licence plate frame. I cut the bottom V bracket off the frame flush and removed the relectors and notched the reflector holes to fit the new holders upper holes. Save those reflectors. I sprayed some black paint on the frame as it was cut and drilled. The black frame now fits perfect behind the new chrome holder. This modification lets the chrome holder sit up close to the fender and looks really good. I put led turn signals inside my tailight housing and bolted those 2 reflectors in the factory signal holes to cover them up. They bolt up perfect with no mods needed. I love the look now and it cost me under 70 bucks for all including led signals. I'll try to get some pics for you. My bike is a C also.
Kuryakyn Side Mount Plate
This is the plate I installed only 103.00 from Xtreme Revolution its not horizontal it is a vertical set-up. I haven't seen a horizontal side mount. I would actually think it make stick out to the side too much. Anyhow it looks great you may consider the vertical. The top is the add picture the lower picture is mounted on my bike.
Discussion Starter · #6 ·
Thanks, IAMDMAN23 I do like the kury license plate very much, I had it on my 1st bike, pics in gallery, I just wanted to find one that was horizontal and not too big. I've seen one somewhere that folds in when your not riding, but I can't find it again. Guess I've been looking too much. I've had quite a few people tell me it was illegal in SC to have the vertical mount. Although I work at the PD and can only find where it has to be lit. I know a few people got tickets in Myrtle Beach, don't know if they are really that strick on it, or if they just like messin with you there. Thanks for the info and the pics. It does look good on the bike, I wonder if the kury drive shaft cover would get in the way, its big. ?? Any way thanks again ! Caroline
this is one i did...CHEAP!
http://www.vtxoa.com/forums/viewtopic.php?t=147490
so i wanted a side mount licence plate. Kury setup was over $150...... F that! i was browsing around at the bike shop and came across a universal plate mount. it was a $4 peice of aluminum with a pre-drilled pattern for moto plates. i can afford $4.....so i got it. i also piked up a $5 chrome frame. then i started getting ideas for the rear turn signal assembly and ways to clean it up a bit. so i piked up a set of clear SMALL turn signals (sport bike style).
ok so here is my shopping list......
-turn signals = $15
-aluminum plate = $4
-chrome frame= $5
-set of 4 licence plate screws (security) = $4
1) start by laying everthing out and get a sense of whats about to take place. measure out the fattest part of your driveshaft near the 4 bolts. take into account the welds also. i used a caliper (not a brake part, but the measuring device
2) mark out your plate as to where you want to chop out a section for the driveshaft. i liked putting it the center...made for a cleaner, factory look. i used a can of spray paint to make the curve. it fits just right!
3) suck it up and chop it. just remember its a $4 part.....if you screw up, just go get another.
4) trial fit your piece. if it looks good, mark your centerline of the two outside driveshaft bolts. drill them out. i did a slotted style hole for making a bit of fine adjustment when on the bike. i only used the two bolts.....but you may feel like using all four. just mark carefully, and run 2 more holes.
5) at this point, everything should line up and fit nicely. i took a file and a dremel to it to clean up all the cuts and holes. you can also put some paint to it too if you want. the nice thing about this is its aluminum....you can leave it milled, polish it out to a chrome-like finish, or shoot on some color.....very versital!
6) bolt it up and enjoy. after your firt ride, double-check the tightness on the driveshaft bolts.
ok so that takes care of the side-mount......but now you have this $#!tty empty bracket hanging from thr rear..... YUCK!
you can just chop it off with a grinder, dremel, hacksaw, beaverteeth, whatever....but i went a little further.
1) unbolt the turn signals and cut the wires going to them. i left a little wire hanging out incase someone wanted to use them on something else. email me if you want them
2) i did the same to the rear licence light. chop it!
3) this is where it gets scary....take an aforementioned cutting tool of your choice and go to town.....i placed a couple strips of duct tape to the painted part of the fender to protect it. GO ON, GROW A PAIR!!!! i found that the angle grinder/cut off wheel did the most effective cutting.
4) take a file or dremel and clean up your hack job.
5) a quick spritz of spray paint to keep the rust from forming. i used Rustoleum flat black.
6) I got a pair of sportbike signals that mount with 3M tape. i liked them cause they are clear and have a chrome-like base. they have a nice chrome look to them when not lit up. i held them up to the side of the bike, and found the place i liked. mine are below and flush with the rear fender struts.
7) mark the spot for your wiring. centerpunch & drill. mine ended up being right on the inner fender brace.....i just drilled through the fender and NOT through the brace. that way it protects the wires from road debris/rear tire.
wire up your new lights and test them. BLING BLING!
9) zip-tie all the excess wiring out of the way. i also ran some zip-ties to help secure the wires to the brace i talked about in #7. i am paranoid about the rear tire getting in contact with the wires.
THATS IT! now take it out for a spin and test everything out. go show off to your buddies. when you get home, double-check the tightness on the driveshaft bolts...better safe than sorry. ENJOY!
I made mine out of a framing bracket. Basicly an L shape with 4 holes on each side. I wanted to come off of the shock mount for the simple fact that I could picture my self scraping my leg on it. After shaping it, I painted it black and you would never know that it was a garage creation. As I do everything else, I made it extremely heavy duty. I stood on it when I was done. here is a picture. I picked up that piece of metal as I was walking my dog on the side of the road one day. cost $0 - time 1/2 hour cutting and welding.
Discussion Starter · #9 ·
Hi Mattready, thanks for the suggestion and it looks great, only one problem, I have the Kuryakn driveshaft cover and it won't work there. But yours looks great. Thanks again Caroline
Discussion Starter · #10 ·
Hi twistedrcpiiolet,
That looks great and is mounted in a place I can use. I have the kuryakn drive shaft and swingarm covers so my choices are limited to the shock mount. I'll see if I can't get the hubby busy making me a bracket. I already have a chrome llighted plate to mount on it. Great idea. Thanks, Caroline
I hate to give away my secret :stirpot: , but mine is not lighted in the conventional way. I got a set of directional led's from autozone that were covered, wired, and water proof and stuck them way under the fender at a 45 degree angle. They are mounted right next to the last bolt on the fender support. This way they shine on the mount and there are NO VISABLE WIRES!!! I'll post a pic of the bracket later. I am making another one for my brother.
damn twisted...that things a beefy mofo! can you pull a boat with that? :D
thats a great idea and looks nice and tight up against the bike like that. do you have any issues with it binding the shock movement? the little bracket i used could easily be used in this same mount....just measure, drill, trim, and give it a nice bend.
are the little holes in the bottom of your fender from the stock brackets?
I have this tendency to break things so i build strong...real strong. I think it's about 1/4 inch galvenized steel with triple beed solid welds!!!.
There is no binding at all I can actually stick my finger between the plate and the shock. I made sure of that. On your bracket, make sure you position it right so that it doesn't rub anything, like the hub or the shock.
I can build one of these for a fair price. I actually have enough material for 4 of these. I figure 30 +shipping.
1 - 14 of 14 Posts
