1 - 4 of 4 Posts
Stage 1: Suspension/ground clearance.
1: Switch to 1800 shocks in the rear, speaking of which... Anyone have an extra set?
2: 2 inch fork extensions in the front
3: switch to 15 weight fork fluid while I'm at it.
4: Add THESE *edit* Ordered! *edit*
Stage 2: Controls
1: Decided if I want to go with Kewl Metal 195's or some of These.
2: While I'm pulling everything apart, (and adding length for the second time) go with a braided brake line, and replace the clutch and throttle cables. Since I'm on a C, I should be able to just order lines/cables for the R/S models and get the extra length I need, right?
3: And go with Avon grips. They will work on a VTX, right?:mosh:
4: And get a fresh set of the Kury wide levers, to replace my clutch lever with. *edit, already ordering these!*
A Texan
There is no plan that can not be accomplished with enough
You've got a good start ..
If anyone has any experience with the mods I'm looking at, I'd appreciate it if they would chip in. Just want to make sure I'd get what I expect.
1 - 4 of 4 Posts
