hey guys, i think i'm having a big issue now....
everything is stock on my 2007 S bike, aprox 10k miles. full tank of premium gas.
didn't run her for almost 5 weeks, the temp outside went from 20-24 celsius to aprox 4-5 celsius overnight, kept the bike in a closed garage.
anyhow: this evening the battery was almost dead (odo didn't light up, the engine didn;t turn, etc). i gave her current from my car, she started fine; despite i'm having glens' a/f opened for 2 turns, she didn;t kept the idle so i used the choke (DON'T KILL ME PLS... i didn;t fouled the plugs, i've checked them !).
i pushed back the choke and bike almost died, managed to keep her from the throttle for half a minute but died... had to give current again from the car, started fine, (so yeah - the battery is flat , although it's having only 3 months!!!) and NOW THE PROBLEMS BEGAN:
when i started to put back the battery and i touched the ICMv - BANG!!!! bike started to spur, misfire, front cyl didn't worked, black smoke from the exhaust, sputtering, etc - all the hell took over my bike !!!.:banghead::banghead::banghead:
turned it off. started again from my car. barely touched the ICM and again the bike went crazy.
i pushed the bike back to the garrage, took off the battery to charge it, i stopped investigating the ICM wires issue (green, black,wrench-tightened battery , etc) as the night came.
questions:
1. why it didn't kept the idle speed? (despite glen's permanent being installed and tuned)
2. everything being stock, why the battery run flat in almost 5 weeks of not being used? (where the h**l went the current from the battery?!?!?!?)
3.can someone help me with an ICM scheme?
4. IF the green, black or other wires are broken (inside the insulation, outside, etc) HOW AM I GOING TO SOLVE THIS ISSUE ? i assume cutting the any wire from some place and replacing it with another one wouldn't be a solution....:banghead:
5. what else might cause the black smoke?
thank you guys once more for your help... any suggestions would be much appreciated
questions:
