I just went over 20K. Got the bike in Mar with 11k. It's been running great. I recently replaced the Hard Krome big straights that were on the bike when I got it with V & H and a hypercharger pro. I successfully installed the new Map to the power comander. After hearing the decel popping that so many have had issue with I performed the pair valve and de-smog removal. The whole time bike running fine after each mod. The pipes had no baffles and someone gave me a set so I tried them out. I didn't install a new map to the PC. Bike seemed to be running fine 45 mile open highway ride to work. Then it happened. riding home speed about 85 ignition seemed to die. A half second later right back on. It's now happened many times since then. All different speeds,rpms, gears. Sometimes when pulling out from a stop off,on off on. Like a damn bucking bronco. I'm in the middle of the ground fix that I've read so much about now and I'm gonna pull the baffles out so I have the correct map. I hope this takes care of it. If anybody has any other advice I'd love to hear from you.
battery bolts...
and check the wires and switch that is on the side stand.... it kills the ignition.. wire loose, switch bad, broken/cracked wire. Bolt for side stand loose????
your re-programmer using vampire clips to connect to bike wiring??? if so.. remove and solder wire connections.
kickstand switch. That's a great pull. The symptoms would have been exactly like the problem I had. Your other guess was closer. after I removed the tank and started on the ground fix, I found the ground wire for my power commander broken at the crimp connector. That was the problem. I actually do have vampire clips connecting the other wires. I will correct that next time I have the tank off. The bike is running great now. I have the same paint scheme on my F model. What a cool bike.
Thanks
