Hi Rico, After removing the headlight you'll see the conectors in question. You have a 3 blade for the headlight. The other three conectors are plug-in's for the switches on the bars. One RED - Two Black And signals, When unpluged from each other there a male pins in one side and female on the other side. The male pins are what I removed. It will be depending on the Bars you chose as to how much wire you will need to add. Are you installing New Bars? Or are you just running the wires threw your stock bars? If you are installing bars that are shorter than the ones on it now you may not have to splice the wires. I'll try to get something going this weekend. And I can talk you through it no problem. The wires ARE long enough to go threw the bars. I just want more slack to hide the wires so they can't be seen until they get back to the headlight. GG.Richard Mendez said:Thanks GG
any pics would be helpful. You lost me when you spoke of taking out the pins from the connectors.You said the wires were not long enough to run thru the bars and would have to be spliced. Is that because of the model X you have or would all the models have to be spliced.
Rico
