1 - 11 of 11 Posts
When bonding two metals together, alot of how good is it going to be is in the preping of the material to be bonded. I have been welding over 35 yrs. and have seen some JB bonded materials last 10 yrs are better and have seen some heliarc or stick welds last a couple of hours. If cleaned properly and mixed as directed you should be fine...
The key to a good repair with jbweld or any two part epoxy compound is 1. good surface to bond to 2. accurate mix of part A and part B of adhesive
I have had some good results using this kind of stuff as long as there is not alot of stress to the repair.
JB weld is good stuff if you use the right 1 and do it right. My hood on my sears garden tractor hinge broke and i fixed it with JB weld, that was 4 years ago and it's still holding. I did use the metal type instead of the epoxy type.
1 - 11 of 11 Posts
