The only thing on the bike not stock the last owner installed is Vanice & Hines short mufflers with baffles. Stock air cleaner.
What would be the recomended carb settings or changes for me to check for?
If the air cleaner is indeed stock and has not been modified. There should be no need to rejet the carb. You will however benefit from installing Glen's Permanent Air/Fuel adjuster. With the A/F adjusted correctly, you have easier starts and no need ever to use the choke/enricher again. With longer plug life as well.
aka "Buddha Bill"
Howdy from Arkansas!.
If you love your X, you'll love this place! Read, read, read the forums! They'll give you all the info to keep you bike purring and a hella lot cheaper the taking it to the stealer!
If you need a question answered, make sure you post it in the right forum.
Rebel
Arkansas
Spend most of my time in Arkansas. I actually live in the hills 8 miles north of Arkansas and 12 miles east of 71 Hiway. Listed joplin because it was the nearest city.
