Kuryakyn turn signals?
2485 Views 2 Replies 3 Participants Last post by  Madness_MC
I want to buy these...
http://www.motosport.com/harley/pro...-KIT/?catalogId=103900&sMMY=HARLEY;FXDWG;2005
Say they're for a harley, want to mount on my VTX 1300c rear fender strut. I can't see why they wouldn't work as long as there's a hollow bolt. Any one know for sure?
1 - 3 of 3 Posts
I say give it a try.
My recommendation would be order them from Dennis Kirk. There return policy and procedure is awesome. You don't have to notify them you are sending them back and a return shipping label is provided. I usually go with Dennis Kirk if I'm unsure about fit.
gfrice -
If they are the larger, 2-wire red Silver Bullet turnsignals for the FXDWG go ahead and order them. I have those installed on my C-model and they're fine. Remember, you will also need to order the separate 4-Amp load equalizer for metric applications, as the H-D models come with the 2-Amp equalizers for H-D applications.
I've sold and installed several sets of them for my local Honda, Yamaha and Kawasaki customers. Everything worked out just fine with the correct equalizer. Most times, I didn't even have to replace their flasher to blink at the proper rate.
1 - 3 of 3 Posts
