1 - 20 of 32 Posts
So, today, I'm following a detour through a neighborhood and take a curve in the streets at around 15-20 mph. Nothing fancy. My bike has Kuryakyn highway pegs bolted onto the frame with spacers that came with the bike when I bought it from a guy. Well, those bastards screwed me royally today.
As you can see:
they add width to the frame just below the footboards and also lower the clearance of the bike below the footboard too. The worst part is....they aren't friggin' springloaded. If I lean too far and the footboards hit, they fold up as you all know. I'm about 90% sure the culprit was this.
So, anyway, back to my story. The bike hits the deck, I jump off onto my shoulder and what not and then I just laid there watching/listening to the screeching, grining metal slide a good 25-30 feet towards an oncoming car. The bike never hit the car and before I could pick it up the chick in the car is asking me if I'm okay of course. I am. BUT, i'm FURIOUS.
I'm no pro or anything, but outside of embarassing this was just ridiculous. I could NOT figure out for the life of me how I had lost control of my bike. What do you guys think? You've seen the photos above. Don't you think this is what laid me down too? The bolt on the outside of the spacer and the spacer DEFINITELY had been hit.
SO. Now, I've got a pair of Vance & Hines Cruzers that are scratched up. That is the biggest ouchie. I can't afford to fix most of this shit. Dumped most of my money on the bike already, so I'm pretty bummed out. I went from riding high on a showroom quality bike (in my mind) to looking like a chump on a scuffed up thing in NO TIME.
I am currently shopping for (mostly making a list, of damages) the following parts to try and reclaim my beauty to health again.
Red Front fender:
*it's barely scratched, but already had a place on it, so I thought I may as well see if anyone has one lying around.
Brake Lever: Scratched
Throttle / Brake cables:
The throttle cable was damn near severed and I barely putted home. The brake cable is not as bad, but is slightly damaged and I don't want to take chances. Also, do the silver "L" shaped pieces that the cables run through come with a set usually???
Fluid Cup and/or Cover
: The cover and cup are scuffed.
Vance & Hines Cruzers: I called Vance & Hines. They're all one piece, so I can't simply replace the mufflers (both of them are scratched but the pipes are fine) I also called a chroming place and they said it'd be cheaper to buy new ones. GREAT.
Brake pedal lever: Bent.
Memphis Shield: Scratched
I will be removing these bullsh*t highway pegs and hopefully the work fairy will shine on me soon so I can afford engine guards.
This BS will set me back on my Mustang seat and Saddlebags fund for quite a while.
If you know anyone that needs a Graphic Designer now would be a great time to throw work my way! I am an accomplished Creative Strategist and Brand Consultant.
:nope:
that sucks dude. Sorry to hear about it
I would say those bolts sure do look suspicious :icon_susp
maybe someone wants to buy your old scraped up pipes? and the death highway pegs. I think the pipes could be painted black if someone wanted to black out their bike.
good luck man
I had those same kury mounts. Mine would touch down before the pegs (C model) but I never lost the bike because of it.
What kind of detour were you on? Was the road torn up? Gravel, Sand?
Sorry to hear about your bike man, but glad you're alright yourself!
I had those same highway peg mounts on my 1300C too. I nearly laid the bike down as I was leaving the dealership the day I bought it! I leaned over too much plus there was a pavement bump and it hit on the lowest part of that mount. Mine was actually rotated up as far as it would go so the mount actually hung down lower than yours.
In my case I was on the gas pretty hard so all it did was cause the rear wheel to lift just a little bit but as soon as it hit pavement again I was back under control. I got home and rotated the mounts as far forward as I could (like yours) and then never dragged them again. If you were on any kind of loose surface then I could easily see this causing you to go down.
But now I have Accutronix Forward controls installed and 2 days after getting them on I scraped the brake side on a down-hill right-hander that's about 90 degrees. Scared the crap out of me but didn't lose control of the bike at all.
Are you gonna put your mounts on eBay? That's what I was planning to do but I don't want to create a competing auction with you if you plan to. Let me know and I'll be sure to scan what's out there before I list mine.
...maybe someone wants to buy your old scraped up pipes? and the death highway pegs. I think the pipes could be painted black if someone wanted to black out their bike.
+1 - put them on the classifieds section. For the right price, I'm sure someone will jump on them and you can use that money towards your fixes.
Sorry to hear about you going down man but we're all glad you're okay ;)
citement
Sorry to hear about it man. You're okay, it's the most important. My crash bars saved mine from any real damage. Those things are worth their weight, no doubt about it.
I have them on my bike and I am sorry you laid it down , it is good to know they can touch the road , I never have had them hit. Glad your OK
Desert Recluse
Throttle / Brake cables: The throttle cable was damn near severed and I barely putted home. The brake cable is not as bad, but is slightly damaged and I don't want to take chances. Also, do the silver "L" shaped pieces that the cables run through come with a set usually???
:nope:
Replace the bad cables.. straighten the brake pedal or replace if necessary... go riding.. scratches don't mean anything... when you have money to piss away you can paint and chrome.. I probably wouldn't tho.
:cheers: :cheers: :cheers:
2º Left of self-centered
+1
After some of the crap I have ridden a few scrapes don't mean squat. Hell, they add character :D
That sucks, looks like I'm gonna have about $2000.00 in mine to get it back up. And I'm doing all but the paint myself. Just be glad your ok.
Discussion Starter · #13 ·
Thanks, everyone. I feel less like a dipsh*t now. My ego took the hardest hit I think. My elbow and knuckles will be fine.
I think I will probably eBay the suckers off to help pay for the engine guards fund. That is the first thing my buddy told me when I saw him post-wreck today. "I told you so. Get rid of those things and get some Lindby's"
@midwestrider: Go ahead and post yours. I've got cables to worry about before I probably put them on eBay.
For the pipes., I doubt I"ll get enough for them to cover the cost of new one's. (or near it) I called V&H and the Cruzers are all one piece so they can't do anything. It's $400 for new one's. I also called a chromer in town and they said they can't dip mufflers cause the carbon ruins the tanks. So...
They're really not scratched all that bad, but you know, with chrome...everything shows. I'd sell em' for $300 I suppose if someone wanted them. Then I'd be out $100 for new one's.
As for the fender. I haven't decided if I'm going to try and touch it up or just by chrome tips and cover them up. Cables are first priority so I can ride again.
@Scar & Rodent042:
I envy your mindset. Unfortunately, I don't share it. I love my bike shiny and new looking. I hate every little ding and scratch and dead bug. My buddy is the same way. "gives character" he says. I say, drives value down and makes me look like a novice rider. haha.
HEY MP,
I'm in the 'boro too. Let me know if I can help u through this bad time.
W
@Scar & Rodent042:
The ego often times takes the hardest blow. ;) Glad it wasn't any worse!
Biddy
Lindbys, you better go for more than just looks
I have heard they fold up in a heart beat.
Do some research befor you decide what you want.
I have the paladins fatty bars and I know they work well in my driveway tip over not even a scratch other than the EGO.
Just glad to know that you are OK enough to fix your ride!!!
Patience with the repairs. Your attitude of fix the cables so I can ride is right on.
Desert Recluse
@Scar & Rodent042:
You're young -- Let me know how ya feel about it 20 bikes from now.
Man, sorry for your luck, bought some highway bars today, I better get the on as you indicated it can happen fast. Good luck
1 - 20 of 32 Posts
