Hey guys i just bought some flexible led light strips to add to my brake light and running light but cant seem to figure out how to make it work for when the key is on they light up and when i press the brake it comes on bright any ideas thanks, also the led strip has 2 12 volt contacts and 2 ground contacts but the brake light wiring only has 1 g/y wire and a brown wire to the light ??
I have a 1157 taillight brake light bulb that rotate and it Flashes when you hit the brakes. Easiest way to do the brake light, just change the bulb.
I also have those led flex lights on my trunk and on my saddle bags. I have those on a separate toggle switch mounted on the side.
Just run a HOT & GROUND from the battery to the toggle switch.
Ok thax ill check the toggle switch out, but question is you say change bulb for tail light and you say it rotates and flashes when hit brake? How does that work i never heard of a bulb that rotates and flashes is there something you did to make it do that?
Thx but i looked it up and dont see or find that name cruiser customizing ? They have another name competition accessories but they dont have that flashing bulb either ?
