1 - 3 of 3 Posts
I just had my led lights installed, a friend gave a me a kit from "LedGlow" multicolor kit of 6 strips...
Seems that on the right side of the bike where the air filter cover is located I cannot light that side up seems that the front is OK but from the middle to the back of the engine seems that I have no luck positioning the lights, I tried behind the air filter cover light gets blocked, any ideas where I can put them ?
:banghead::banghead::banghead::banghead::banghead::banghead:
Try putting them under the tank....you can "splice" the wires and have a "quick disconnect" there for when you have to remove the tank...
I also put some LED's on the backbone by the battery...
I have two strips under the tank, but light gets blocked by the air filter cover.... I have not tried the backbone of the battery ... Hummm..
1 - 3 of 3 Posts
