Yes, but you will have worse visible light than a halogen bulb... LEDs do not work well in reflectors designed for halogen bulbs. They will appear to be brighter (because they are), but they spread light all over the place, and less actual light in the correct pattern.Will just a regular LED bulb work on my 2006 VTX 1300c without changing anything?
While you can plug n play an led bulb and it’s easier than installing a Daymaker, it will be a roll of the dice in terms of how the light pattern is, and as with mine, will require quite a bit of adjustment to get it right. Do I like it better than the stock bulb? Yes. If I wasn’t too lazy to install one would I prefer a Daymaker? Yes 🤙Will just a regular LED bulb work on my 2006 VTX 1300c without changing anything?
