1 - 12 of 12 Posts
i cant find the thread, so i'm asking. there was a thread about doing the seat mod for the 1300 c, without having to drill out the hole, in case i ever want to put the bolts back in the future.
i'm looking for the size of the pull ring pin that will fit the hole, without any drilling. thanks to all :patriot:
· Klaatu Barada Nikto
seat pin mod....
Discussion Starter · #8 ·
okay guys. thanks for the help. it just came to me not to sweat it too much. i'll remove the seat bolt right there at homedepot, buy a size 5/16 or 1/4 and work my way from there. :hmm2: :idea:
boy, at times, i'm really brilliant :nono:. i was just testing you guys to see if you could make it easier. :icon_bs:
thanks again, for the measurements, when looking at the 1/4 and 5/16 that's when it hit me. go figure. sometimes 8 heads think better than one. that's why i like this place... :icon_danc :mosh::D
i'll see if i can get it done before saturday Javy, if not, then sat i'll have the answer. thanks for the help. ever put the regular 1157 in the front?
Ok man, thought you had it done. Yep, put the 1157 bulbs in the front and all is good; thanks for all the help bro! :mosh:
Discussion Starter · #12 ·
So Luis, what size pin is it then, 5/16" or 1/4"? :kidding: :patriot:
okay brothers. haven't wanted to order the rings from Mcmaster carr since the shipping is more than bolts or just as much. i found a pair of 1/4" but they are not thick enough. they slide out, so it's the 5/16" that will fit.
i'll have to wait to be ordering something else, or just drill out the 3/8 which i have the rings for. the length has to be at least 1" or .08 useful length. the 1/4 " one that i tried was 1 1/8" long and would have worked, and still had some room to go in deeper, so you'd be more concerned with minimum length than maximum. of course, this is on my 13 c, not sure on other models. so this is over:icon_blah!!!
thanks alot for suggestions and help. :mosh:
anyone asks about this we know now or now know, it's the 5/16" x 1" or slightly greater. :) :choppersm
1 - 12 of 12 Posts
