Mix blue and green honda coolant
176 Views 6 Replies 3 Participants Last post by  sumncguy
Does anyone know if I can add blur honda coolant to existing green honda coolant ?
Don't really want to drain. Bikes up on a stand getting worked for a long trip.
The water pumps are sometimes prone to leaking after draining.
Just want to add cap and put it all back together.
I think as long as neither color has added silicates (they are bad for the water pump), you should be fine.
[/QUOTe
Yeah I hit the honda oil site. Blue and green compatible
Thanks
Honda Type 2 blue is a LL coolant. (Long Life) You can mix it with green but you will cut down on it's life expectancy. Blue is good for 5 years, green is good for 2 years. Mix the two, how many years is it now? If you change your coolant regularly it shouldnt be a huge issue.
Check out the honda oils site for more info.
This info is direct from Honda Pro "Advanced Type-2 “Blue” formula is 100% compatible with and replaces the original “Green” coolant."
Yeah ...
