1 - 1 of 1 Posts
· Vendor
Motorcycle covers designed and produced by the Covercraft company based in Oklahoma gained popularity in recent years due to their high quality, functionality, and reasonable price. If you need a great cover that can protect your parked motorcycle during the off-season or when you simply leave it outside for the night, you will not regret purchasing a top-notch Covercraft cover.
The company uses the latest innovations and advanced materials in the production of their covers so that they could effectively protect your motorcycle from bad weather and other harmful factors that could cause the accelerated wear of your bike’s components. Even if you have indoor storage space for your machine, you can benefit from covering it with a special extra soft Covercraft cover protecting it from dust, dirt, debris, and even minor scratches.
Covercraft® - Form-Fit™ Motorcycle Cover
Features:
• Body-hugging polyester knit outer shell is made with spandex (to provide stretch and recovery)
• 100% cotton terry loop is added to the underside of the shell during the knot process and then sheared to a luxurious fleece finish
• Fleece provides a super soft touch against fine paint finishes, wind screens, chrome
• Form-Fit covers follow every curve of the bike for a truly custom fit
• Easy to clean - just throw it in the washer & dryer at home
• Form-Fit covers carry a lifetime limited warranty to the original purchaser
• Covercraft will repair or replace any cover that becomes unserviceable during normal use
Covercraft® - Ready-Fit™ Deluxe Silver Motorcycle Cover
Features:
• Silver-colored urethane coated polyester fabric reflects heat, is waterproof and lightweight.
• Heat shield along bottom of cover where it contacts engine, pipes and brake rotor.
• Includes screened air-vent to allow condensation and vapors to escape.
• Theft-resistant non-scratch grommets are surrounded by a multi-strand steel cable sewn inside covers.
• Elastic in the hem at front and rear helps hold the cover in place.
• All seams are overlapped and double stitched for superior strength.
• Ready-Fit silver urethane covers carry a two-year limited warranty to the original purchaser.
Covercraft® - Pack Lite™ Semi-Custom Full Motorcycle Cover
Features:
• Super compact - covers store in 7" x 7" x 8" or less
• Weatherproof - Fabric sheds water as soon as it hits the cover
• Superior Dry Time - Because the fabric sheds moisture, just shake any surface moisture off the cover and it dries in minutes
• Breathable - Allows any heat, condensation or vapors under the cover to easily escape
• UV Resistant - Special finish additives minimize UV degradation and protect the bike's finish, seat, instrument cluster and windscreen (if applicable)
• Dust-proof - Patented fiber encapsulation process prevents dust from filtering through fabric
• Abrasion resistant - Polymers are smooth and silky to prevent paint and windscreen abrasion
• Fade resistant - Means color goes all the way through fibers
• Easy care - Clean the cover in your home washer and dryer
• WeatherShield covers carry a lifetime limited warranty to the original purchaser
Click on the image to enter the product page at MOTORCYCLEiD.com for more information.
To browse the full catalog of Covercraft products, click the "Shop Now" button below:
Give our sales team a call at 888.903.4344 (Toll Free) or 1.732.867.9995 (International) and we'll match any competitor's price.​
1 - 1 of 1 Posts
