First of all, great forum! I’ve been reading/using this site a lot. I’m a NOVICE so any help I can get would be greatly appreciated.
I’m working on a 2007 VTX 1300R that my brother bought new in 2008. He had Cobra pipes put on by the dealer when he first got it, but no other mods have been done. I’m not sure if they adjusted the A/F when they installed the pipes, but it’s always seemed like it‘s run lean when idling.
Here’s a quick history from the last month or so:
1). The bike periodically would not start like it wasn’t getting any gas. I could ride it, park it, not be able to start it 20 minutes later, and try it again 20 minutes after that and it would start right up.
- Therefore, I replaced the Petcock and the vacuum hoses, and haven’t seen the issue again (yet at least).
2. The bike ran well after that, except it would backfire when decelerating while riding.
- From reading the forum, I installed Glen’s A/F to adjust the the mixture
- I made sure that the existing needle came out with the spring, washer and rubber grommet, and put Glen’s back in with the same 3 things in the right order.
- When I first put the air box back on, the idol adjuster got stock behind the box so it didn’t seat correctly. So when I started the bike it was running very lean, and I had to give it gas to start and keep it running.
- Not knowing what the problem was, I made adjustments to the idol and A/F to try and richen it up.
- I then found the problem with the air box and reseated it correctly (I think)
3. NOW, I’ve adjusted the idol to about 900 using an inductive tach and backed the A/F valve out about 2 1/4 turns.
- it seems to idol pretty well now, but as soon as I give it throttle, it coughs bad or dies completely.
As you can see, I haven’t done much (Petcock, vacuum hoses and Glen’s A/F), but can’t figure out what is causing it to run rich and die. It’s got to be something really stupid I’m doing wrong, but can’t figure it out.
Should I put the original A/F valve back in? Vacuum problem?
Any suggestions on what to try next? Thx for your help!
