On the carb diagram for the 1300 I see a part labeled "Needle Set" (Part #2) which appears to go inside the carb above the main jet. Am I reading the schematic correctly? Does this screw into the main jet hole above the main jet? Let me ask another way. Are there 3 pieces to the main jet assembly? Or is the #2 on the schematic set further inside on the bottom of the carb, permanently attached?
