got my 07 1300C about 2 months ago with only 4600 miles on it, so it wasn't ridden much to begin with and I'm sure it sat for a while before I got it. A little carb/fuel injector cleaner went a long way in getting it to run better right away. I decided it was to quiet with the stock setup, so I drilled out the pipes following the advice I found here on the forum and am happier with the sound now. 1300 miles later, it's starting to backfire/pop occasionally on decel and while cruising (I think this means it's running lean????). I'm sure that the carb is probably in need of tuning/rejetting. I am considering putting a Baron's BAK on the bike and figure it's best to do that and the rejet at the same time.
My 3 big questions are: 1. Are the intake and rejet truly simple enough that if I can follow directions I shouldn't be afraid to do it myself (not very familiar with carbs) and 2. Will I need to immediately replace the exhaust with a more free flowing system, or will the stock exhaust handle the air kit and rejet being drilled out? 3. On a side note, the front forks are really soft/slushy and I would like to stiffen them up quite a bit (I always rode sportbikes until now) - would I be better suited going to a heavier weight oil, or using a larger amount of the recommended weight?
I know that's a lot of info, and I apologize, but I am excited to see what this bike can really be and with December upon us, even here in Central Florida it's a good time to tackle these projects as I won't miss much riding time.
Thanks in advance for the help as I have already seen what a great community this is. :cheers:
