Took my rim and tire to the dealer for rear bearings and a yoko darkside install. 25k on my 03 1800. I should get it back this week.I never noticed any noise but I sure will be listening, now. Come to the tech session in May!
You can check to see if there is fluid in the final drive. Park the bike on the kickstand and remove the filler plug, fluid should be up to the point where it just flows out.
Put the bike on a stand and spin the wheels by hand. You may be able to pinpoint the noise to the front or rear of the bike. Things like the front wheel bearings and both the front or rear brakes can cause such sounds.Thanks, I will try that when I wake up in 6 hoursany other suggestions guys???
Cricket noise could be your brakes......I know my fronts make that noise...like a ciccada. Or is your noise more of a squeak?
The brake pads can make the cricket sound against the vent holes in the rotors. Some pads are louder then others. So if the brake pads were changed out the perhaps the brake pads are dragging more than usual for various reasons, the sound may be there all the time.No, sounds more like a Cricket, but only under load, thats the confusing part:hmm2:. Also seems to be more noticable when wife is on the back.
