1 - 4 of 4 Posts
I have a 07 Honda vtx 1300c, and the rear running lights are not working. I checked connections, and are ok. Bulbs are good, but they have only one element. Turn lights are working and brake light is working too. But not the running lights.
Are the rear turn signals AMBER or RED? Stock is AMBER, no running light on stock rear, just turn signal, hence one filament, rear running light must be RED. If rear turn signal has a RED lens, then a R/T/B (run-turn-brake) kit has likely been installed.
In the stock configuration, the only rear running light is the taillight. Custom Dynamics has some options for a rear LED run/turn that you will need to run an additional wire to accomplish what you are asking about.
1 - 4 of 4 Posts
