· Chap Dawg
I don't have a motorcycle jack. Any issues with installing Dyna-Beads if I deflate on the ground and remove the valve cores?
That is how I did mine. One tip is if you have an engraver press the side of it against the valve stem as you install them. With the vibration they flow right in. Another tip is do one at a time, after you fill them you want to roll the tire a 1/4 turn, fill it and set the pressure them do the next. Trying to do this with 2 flat tires is a work out, and yes I have personal experience with this.:icon_redf
· Chap Dawg
Great advice! I'll be sure to do one at a time. Thanks!
· Darkside Pastor & Addict
If you are going to do this without a jack, be sure to put the valve at the side otherwise it will be much more difficult to get them in. Just my .02
Pdave
