:doh:
Ok so I am trying to figure out the best way to connect my radio/amp without harming my electrical system. Several years ago I put a power distribution block under the left side cover. I thought it was wired hot all the time and therefore, needed a relay to connect my radio. What I found when I pulled off the seat was that I have the distribution block fused with a 30 AMP fuse and it is SWITCHED via an ignition wire. So, the block is only hot when the bike is on.
So here is my question. Will it do any harm if I wire the radio/amp to this switched block without a relay or should I also install a relay just for extra protection?
Appreciate all input.
This is driving me just a bit crazy.
Regards to all,
Jack
Regards to all,
Jack
