Optimal tire pressure?
4 reading
11K views 6 replies 6 participants last post by  SPARKY5151
#1 ·
I've owned and ridden motorcycles for over two and a half decades, and if there's one thing that everyone has a different opinion or preference is tire pressure. now I know tire pressure needs to be adjusted depending on the load and what kind of riding one does but my question is what is the optimal tire pressure for both front and rear for a 2006 VTX 1800 C?
I've been keeping my rear at about 38 psi and my front at about 36 and I don't notice any uneven or excessive wear thus far as I do check my pressure probably at least once or twice a week.
I don't particularly ride hard and kill it on the corners but I do ride quite often and there are some twisty roads here in Ontario Canada.
Some of my riding Buddies swear by keeping both front and back at 40 PSI for Optimal Performance and tire longevity.
Tell me 40 PSI sounds somewhat excessive but I did want to get some feedback based on experience and trial-and-error from some of you. Any feedback would be greatly appreciated
#2 ·
If 36/38 works without excessive wear stick with it. I dropped my front to 36 and liked the feel but saw cupping in several hundred miles. 40 just doesn't feel right to me so I run as high as I can without it bothering me. Currently running 39 and hoping I just get used to the feel. I'm 230lb and often have another 200 on board.
Tires also matter. At 40 my old Metzeller was horrible but my new Avon tolerable. I don't recall my past bikes being as sensitive to pressure as the VTX so it may just be in my head. I look forward to hearing other opinions too. Thanks for bring up the topic.
#4 ·
Lower pressures may seem to ride smoother, but it will def. affect the mileage you get out of any tires. I run 40 front, 38 rear, but I'm darksided on the rear. 5'10", 215# mostly solo. I run Ride-On sealer/ balancer in my tires.
#5 ·
I was always 40/40 on my 1300C and now 40/42 on my darksided (and heavy) 1800R
Play up and down a pound, I doubt you'll see tremendous difference......
PS
Most gas station air pumps and certainly home guages read differently and not that accurately when you're talking about 1 PSI. Hot or cold tires make a differnece too
#6 ·
Completely agree! I only check my tires after my bike has been sitting overnight doing sure I'm checking cold PSI. I always thought keeping it at 40 PSI will wear them out faster. But some of the guys that I ride with swear by it. Obviously I'm concerned about safety but my primary concern is I want to insure longevity as I don't feel like buying new tires every season haha
