I'm a little confused about this modification. Can I just order a dimple cover and replace the old cover? do I take off the reed valve assemble or just leave it on and use the dimple plate
Honda VTX 1300 Desmog | Bareass Choppers Motorcycle Tech PagesI'm a little confused about this modification. Can I just order a dimple cover and replace the old cover? do I take off the reed valve assemble or just leave it on and use the dimple plate
I think you answered your question...Takes 30 seconds to grind off the screw end and remove the screw. Why pay more?
Thanks I’ll get some new gaskets and try that outAfter I removed mine, and used the dimpled plates, I still had the de-cel popping. When I later replaced the exhaust gaskets, that eliminated probably 90% of it. So if the gaskets aren't removed before re-installing the pipes, it'll happen again. They are a crush gasket, intended for 1 time only. They are very hard to see and not exactly easy to remove. But they're there. Many threads about this. If you run a fuel manager, such as PC III, the best settings are 2,0,0 with the 2 being richer down low just for that reason.
