1 - 20 of 25 Posts
Sexy rims you got there. That will really shine with those lights. :D
FREEBIRD
Hang on a sec....what the hell kind polishing setup you got going on there? There's a belt over that rim!
FREEBIRD
Haha, I like it! (y)
Reactions: sumdatx
FREEBIRD
So how long would each rim take?
Reactions: sumdatx
2005 VTX 1800 F Titanium tribal, 2005 VTX 1300 C Red
Kudos for the polishing rig as well as the results! Great Job!(y)😁😎
Too short for my weight
Looks really good Mike!
Reactions: ironmk
Sweet!
Reactions: ironmk
a wheel truing jig...
first time, its LONG hard Work
do it once a year... an hour or 2... for the wheels.
I have the type II, when bike was one year old..
I block sanded the flat areas of rims .. to remove the machining marks
the power buffed, then hand polished..
I do the wheels, front Fork triple trees, lower fork legs, handlebar levers, master cylinders, lettering on the brake calipers. turn signal mounts, rear fender rails.
every year.
clearly.. I much prefer Polished Aluminum then Chrome.. for a very long time...
for one thing.. chrome can not be made to look better,,,, aluminum can be.
Can you detail your process? Did you start with 220, and work through to 1000. Did you power buff or hand buff, what did you use for compound. After polishing, did you have tiny black spots where the oxides were, or did you sand deep enough to get them out.
Look up white diamond polish and use 0000 steel wool. No wheel rig required just some elbow grease. It's a couple hours at least first time but yearly touch up goes much faster.
Discussion Starter #18
I use a truing stand and harbor freight buffer and an old mower deck belt. First pass 400 grit then 800,1500,3000,5000, 0000 steel wool with polishing compound to finish with 0000 and White Diamond. I have right angle drill to use on the “spokes” to keep from loosing a finger and all steps but polishing I use water to keep from loading up the sand papers. It’s not a chrome finish but darn near it!! It can be done by hand but I think the machines help achieve a much nicer result for me.
Deplorable #2
1 - 20 of 25 Posts
