1 - 2 of 2 Posts
My front turn signals are erratic. Sometimes they work, sometimes they don't.
When they do work, there is a 5 to 10 sec lag in time before they come on.
I've taken the switch apart, checked it and cleaned it. No luck. The rears
seem okay. It could be turn signal module behind the right side cover.
I have had many bikes, and never had a module problem before. Any
one ever have this problem, or any thoughts on it.
Thanks
check the grounds for the fronts...
if flasher.. 2 would act the same. ( left front/rear ) ( right front/rear)
also check the bulb sockets... for rust... my 05 had a little in both rears......
rust in socket.. NO GROUND for that bulb.
1 - 2 of 2 Posts
