1 - 3 of 3 Posts
Quick release brackets with saddlebags. Sold.
Sold
  • Leather saddlebags (13-1/4" (L) x 10" (H) x 5" (D) about a 25 degree slant) with removable mounts.
  • Each bag has extra support inside that bolts to the mounting bracket.
  • 4 keys.
  • One bag has scuff/rub mark from a tire (from another bike).
  • 8mm x 60mm mounting bolts with latching collar, thick and thin spacers.
  • Remove the fender stay bolts, install the collar, thick spacer and additional thin spacers as neccessary so the collars are in the same plane.
  • Good to very good condition.
  • Can be adjusted to fit fender mounting stays distances from 3-5/8" to 7-1/2".
  • The locking collar stays on the bike.
  • The collars are 7/8"(D) x 13/16"(L). They stand off from the fender strut by a spacer that's 9/16(D) x 5/8"(L). Some thin shims are need to set the collars in the same plane.
  • $125 + shipping from 94539.
  • Email: [email protected].
Will this fit a 2006 1300S? If so, can you tell me what shipping will be to 19806?
If the fender stay bolts are more than 3-5/8" and less than 7-1/2" apart, the brackets will adjust. It appears two of the three fender stay bolts are 10mm. The locking collars and spacers are 8mm. Drill them out. Or, run an 8mm bolt through the 10mm hole and use a locking (nylock) nut.
It will be $20 to ship.
1 - 3 of 3 Posts
