2006 1800C
The bottom left support tab on the radiator is leaking. Search results say this is a common defect. I've read about JB Wet Weld but I'm not one to trust epoxy repairs for the long haul. Has anyone found a welding method to fix this. Do you know if the bottom of the radiator is aluminum and is the tab carbon steel. If both were aluminum I could have it welded. But it looks like Honda just drilled two holes in a steel tab and spot welded thru to the aluminum.
Searching the web has all sites showing the radiator on back order. Time to supply is unknown.
Suggestions?
Suggestions?
