1 - 19 of 19 Posts
I removed the tank stickers and reflectors right after I got the bike, but still have the stubborn residue that's just an eye sore and need to get rid of it. I have done searches and tried Goo B Gone and WD40 with no avail.. Anyone have any other fixes for this? Thanks in advance!!!
Dragon Slayer
Depending on how long the stickers have been on, it could take several wipe downs with wd-40/goo gone for the residual marks to disappear. But they will in time.
Maybe I'm doing something wrong then.. How long should I let it sit? I have tried saturating a rag with WD40, putting on a nice coat, and let it sit for an hour or so with no luck...
I used alcohol on mine and it took it off after a few tries, followed with a fresh coat of wax. Just be careful... the clear coat is very easy to scratch up if you wipe it with something to abrasive.
never had a problem with WD-40.......just wipes right off for me.........use it all the time ..........
I just bought a 2007 VTX 1300, so its been sitting in a crate for a while. I used a hair dryer, warmed it up a bit, and took the sticker off. Some goo was left, and I didn't know what to do. Thanks for the WD-40 idea. Does it hurt the paint or wax?
NO..........the wd-40 will NOT hurt the paint at all......just spot wash and maybe re-wax the area after the goo is gone.......
Discussion Starter #12
I left a rag soaked in WD40 sitting on the spot overnight and it still won't wipe off... Used a clean, dry rag and even wiped a bit more on just to try but nothing.. Thinking about using an old flexable plastic card and very carefully trying to work it off...
Miles: 50,000+
I'd stay away from the goof-off and go-b-gone type products. I have heard some bad things about them on paint.
WD-40 is great. You are on the right track with soaking a rag and setting on the goopy area. I know its the wrong time of year, but sitting the bike in a hot sun will do wonders with removing this junk.
Take the suggestions of others and heat it up real good with a hair dryer and let it soak, maybe over night, and heat it up again in the morning to help break the junk up. It's gonna take a little elbow grease to get that stubbern stuff off, but it will come off.
DO NOT USE PAPER TOWELS! They will scratch your tank/painted surfaces.
I used purell hand sanitizer on mine, worked okay but required a lot of rubbing.
Good luck.
I saturated a rag with WD-40 let it sit on the goo for a couple of minutes and then used elbow grease....just had to wipe it a push on it. I'd think that the cold wouldn't help though. Try the hair dryer as stated or a warm garage.
Discussion Starter #16
It, got down to the low 20's last night and is only going to be 30ish today so I might have to break out the extension cord and borrow a hair dryer.
Again, thanks a bunch for the advice!!!!!
I discovered quite by accident that Shell 87 octane removes the residue instantly when I spilled some gas on the tank while filling up. One wipe with a paper towel and it was gone.
1 - 19 of 19 Posts
