1 - 15 of 15 Posts
I noticed a slow leak in my new (800 miles ) rear tire ,upon inspection I discovered a nail , dead center of the tread .It's losing approx. 25 lbs a week. My question is can I have it plugged or patched or am I looking at buying a new tire ? Safety is my main concern .
Replacement is the safest course of action. I have patch plugged and put ride-on to balance a tire with the exact issue.
I have ridden on plugged motorcycle tires for many thousands of miles on two different occasions. It is not only quite reasonable to do this with an internally applied mushroom plug, I do not think there is any problem with doing it on an externally applied "strip" plug. I have never heard of a plugged bike tire failing at the plug. I am sure it has happened but our odds of getting hit by a deer are probably higher and yet we still ride. Plug it, ride it, and do not even think any further about it.
Deuce
Plug it and ride on just keep an eye on the pressure.I have plugged many tires and rode them for many thousand miles. I do replace them sooner than I would a tire with no plug my experience has taught me when the tires is getting bald the plug will not stay in the hole. I just make it a point to replace it a little early but otherwise ride it and keep an eye on the pressure
I've plugged rear tires and rode them until they get nearly bald several times... A front tire plug would only be until I could get another tire installed though!
Faith Fears Not
IMO, with a plug the worst that could happen as a result of that plug is a slow leak as long as you stay aware. You need to do what you are comfortable with though. I have plugged several and never had a leak at all. The extra awareness may even help you find the next puncture before it's problematic.
Reactions: sumdatx
I've ridden on small punctures like that with nothing but slime for the life of the tire. I mark the side of the tire and watch the puncture and the pressure. Typically not more than a drop of slime comes out.
Faith Fears Not
The VTX1300S has an inner tube. You can install one
While true, a tubed tire has a much greater chance of sudden deflation than a tubeless plugged or not plugged does.
Sorry, I misread your post. I agree, a nail can certainly tear a tube yielding much faster deflation than a plugged tubeless tire. I think the risk in plugging a tubeless tire revolves around damaging a belt / separation. This sounds like a minor repair that should be monitored but likely won't be a problem.
Faith Fears Not
I was replying to loayk who suggested installing a tube. I think the OP has a C which is of course tubeless and I would not put a tube in it myself and consider a plug a better/safer repair of a tubeless tire.
Of course it's all going to depend upon your method as you're turning a small hole into a big hole. On using the rope type plugs I have used this many times successfully using the plug and generous glob of rubber cement. On my old Virago I ran the back down to a slick and the plug was fine. On car tires I noticed slow leaks developing sometimes if the puncture was between the tread with the rope type plugs. I have since bought mushroom plugs and tried them out on my 4x4 and they worked fine, but I didn't keep the tire long. I wouldn't use them on side wall punctures.
1 - 15 of 15 Posts
