1 - 8 of 8 Posts
The right mirror vibrates so bad that you can only tell if something is behind you not what it is. The left mirror always has a clear image in it. What could be causing the right side mirror problem?
I honestly don't know....my problem is opposite. My left mirror vibrates like crazy. I've wondered if changing out my neck bearings (haven't done so yet) would alleviate the problem.
Gator for life
I was wondering if anyone has tried using a thin rubber strip wrapped around the bars under the riser caps. Seems to me maybe it would take up a little of the vibration but not sure. Might have to try it one day.
Woody, that is good thinking, i think :D It might make a difference and it's easy and inexpensive enough to try. :choppersm Bry
I found that because I've adjusted it so much that it's become loose .. not at the stem/bar point, but at the actual mirror pivot joint. I was thinking of maybe spraying a bit of degreaser in there to get the opposite effect, maybe it would get stiffer?
Gator for life
Well, if it works, I guess we can call it the Woody Handlebar mod. :D
Discussion Starter · #7 ·
Damper
Read somewhere the bars have damper inside on both sides. Is this true and could this be the cause of the problem?
I have heard that sometimes putting end weights inside the end of the bars will reduce the vibration a lot. I havent tried it yet, but it sounds like it might work.
also it might be :icon_bs:. Bry
Geeze, then you might have people pestering you to find out where to get the
wooden handlebars or the wood polish to shine them up real nice. awww, sorry, that was just lame and silly :eek: bry
1 - 8 of 8 Posts
