1 - 19 of 19 Posts
Dear friends,
My question is why almost 80 to 85 percent of all motorcycle mechanics are telling me " I should always use lower octane gasoline like 86 octane rather than higher octane like 91.
I have also mentioned these mechanics the owners manual is suggesting highest possible octane, but most all mechanics are complete opposite.
Sincerely,
Keyqu
bike milage: 85mi(got it 3 weeks ago)
altitude: 5500 to 6000 ft , NM, USA:choppersm
· Darkside Pastor & Addict
Your 1300 will run best on 87. Anything higher is a waste of money.
Pdave:patriot:
+1 ...Higher octane gas than the recommended 87 octane is of no benifit, and is a waste of money.
Discussion Starter · #6 ·
Thank you guys, most all mechanics are suggesting the same, and they have some "minerals being rich " on higher octane gasoline , thus leaves residue in engine ; type of argument, which sounds reasonable, but why Honda people couldn't figure this out.:choppersm
I try to a avoid ethanol blends. Still 87 octane. It is harder to do. I use Lucas Oil ethanol gas treatment when I use a station I am unfamiliar. 1oz per 5gal. Splash and go. I did notice a difference that the engine ran a little smoother when I went on a week trip. 1 16oz bottle lasts 16-25 fillups as I usually put 4 in. This engine and rubber hoses do not like ethanol.
Is there a sticker on a pump that shows E10? I don't remember seeing E10. Indiana and Michigan for instance do not require pumps to be labeled. EPA allows for up to E15. E85 requires a sticker on the pump. Most Midwest distributors sell E15 In States with no label requirements. On my trip I pumped once putting in 4.5 gal and didn't put the additive in. I could tell a difference on my 1800.
· Pursuing Perfection
use lower octane 86 octane vs 91.
Really?
What do you notice when using either?
Last time I did - there's no way I could tell -
· Super Moderator
Thanks for comments. I am in Ontario, Canada and our lower octane is all a blend. We have to go higher octane ratings to get ethanol free gas.
On your gas pumps does it state a calculation method for determining octane such as "(R+M)/2"? I ask because there are multiple ways to calculate octane that yield different values for the same fuel. Maybe Canada or Ontario is different from the USA.
G'day,
Vinish
1 - 19 of 19 Posts
