That's great Dan! I know people will be pleased with these units. :mosh::choppersmI now have all the factory connectors to make my controller plug and play on all VTX's. Units here waiting waiting for a new home :cheers:
It does not flash the rear brake. My unit converts the rear signals to running light, brake light and turn signal functions because of that by law you must make sure the rear signals illuminate red in color. It's illegal to have rear amber running or brake lights. If you don't want a r/t/b function there are other alternative out there I could wire up for you using the factory connectors. What all functions are you interested in?Sorry I got a couple of question. Does this flash the break light? If so does it go solid after a period of time?
Also how would the flasher work (you said it was difficult to turn on using the stock switch). I'm considering going to a red/yellow break/turn LED signal light instead of the stock rear signal lights, I assume this would still work with this system?
Fast shipping and tracking info provided quickly. Got it today and installation was a snap. Followed the directions provided with pictures making installation smooth. Connectors and the unit itself are OEM quality! Didn't realize it had the turn signal cancellation built into it when I placed my order. Freakin' Sweet!
I didn't know why I was holding out on buying others that didn't install as easily but provided similar functionality. But I'm glad I did.
Thanks again!!
Thanks guysX'N is De' Wirin Guru!atriot:
Q1: No the brake light has no bearing on turn signal function or timing sequence.Kinda of a silly question, but I was about an hour away of going down the kisan road, untill I saw this post! Question 1, does the turn signal timer start when brake is released, and question 2 is really silly but are red lenses readily available for rear running/turn signals!
Thanks, cmon payday!
Thanks!clear alternatives now sells the turn signal lenses in red.
http://clearalternatives.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CA&Category_Code=Cruisers
1 yearHow long do you warranty this unit?:hmm2:
Red lenses are available from a company called Clear Alternatives. Anyway, I bought mine from Phat Performance http://www.phatperformanceparts.com/Clear_Alternatives_Colored_Turn_Signal_Lenses_for_p/cts-0020.htmquestion 2 is really silly but are red lenses readily available for rear running/turn signals!
