I just bought a left over 07 vtx 1300c, i ordered v& h bigshots , should i do the pair valve removal or scar mod, or both? the exhaust is the only mod im doing for a while
His Excellency
Definately do the pair valves. Scar is not necessary with just pipes. Be sure to change out the exhaust crush gaskets and turn out the A/F screw from lightly seated to about 2 1/2 turns and don't use that choke knob.
What they said...No need to dig into the carb until an airbox mod is done...Changing pipes isn't gonna draw anymore air into the restrictive stock airbox...
That Just Happened!
Since the bike is apart with the process of pair valve removal, decap the airbox. Then you will need to do the scar mod. Easy and cheap way of keeping it stock with performance.
