Bonjour tous les mordus de 1800
complètement nouveau dans votre (vtx café)
j'aimerais bien trouvé le lumineux de la vibration de mon vtx 1800c 2002
il shake Quand j'accélère instantanément se rencontrer en mode (torkage)
ça provient du moteur c 'est sur ce qui
se manifeste à la suite de la circulation à la vente en ligne au
siège se rencontré à vibre et à tous en cours de diffusion en attendant en vitesse de croisière quand il ne force pas il devient doux et jouissif qui lui
parle force légérement ????
je me demande s'il n'y a pas été conçu comme ça de l'usine
mon vtx possède un commandant de pouvoir et hyperchargé plus d'après l'ancien proprio n '
a jamais été calibré sur un dino serais-ça le lumineux
merci de votre aide ...
jean
Deplorable member
Deplorable member
jean
Hello all the fans of 1800
completely new in your (vtx coffee)
I would like to found the bright vibration of my vtx 1800c 2002
it shake When I accelerate instantly meet in mode (torkage)
it comes from the engine it is on what
manifests as a result of the circulation to the online sale at the
headquarters meet to vibrate and all in the course of broadcasting while waiting in cruising speed when it does not force it becomes soft and enjoyable which
speaks to him force slightly ????
I wonder if it was not designed like that of the factory
my vtx has a power commander and hypercharged more according to the old owner '
has never been calibrated on a dino would be the bright
thank you for your help ...
jean
Sorry Jean, just funning with you but this is what it translates to.
While I am not in the least knowledgable in that language, from the loose translation provided by Hiramsaint, could it be that you are experiencing what we call "lugging" of the engine? This occurs when you roll the throttle while in too high a gear at any given speed, and the engine really labors to make it go faster. The solution is to keep your rpm's higher than you do now. Lugging is also harmful to the engine. You can look up the term, and read tons about it. Good luck, and welcome from central Pa. high atop the Alleghenies
PS- could someone be nice enough to provide a verbatim French translation of the OP?
