Just put on SPyDER mod on my air box my question is how do you know if you have to shim the needle. Im going on a 6000 trip in 3 weeks and want to get her running right before I go. How do you know if you should shim up the needle and how much do you shim.
How is the bike running?
Any hesitation pulling away from a stop?
Usually when more air in introduced you will first notice a hesitation around 1500 rpm, which I believe indicates that you need to lift the needle a little.
I have a SPyKER air box, K&N filter, and Bubs. Scar mod with 2 Shims and at about 2 1/2 on my A/F screw. Runs great!
Equito Passim
depends if it is a closed or open Spyker Mod
hows the bike running?
-Gonz
Discussion Starter · #6 ·
The bike has a hesitation when you give her gas at take off.Then she runs great but in the wind she acts like she is getting bogged down.
Adjust the A/F screw to 2 1/4 to 2 1/2 turns open and add 1 shim
