1 - 17 of 17 Posts
Senior Linux Advocate
I was wanting to adjust my rear suspension because it has felt very stiff to me. I had to remove the saddle bags to change them.
I had been thinking they were both set to level 5. I thought it should be set to that for two-up riding.
Anyway, because of how stiff it felt I decided to set them back to 3. Well, I found one was set to 3 and one was set to 5.
Is there any concern with this? The bike's been set like this for 3 years unless someone changed it "for me" while I had it parked somewhere... (The saddle bags are relativity new.
I might as well ask, if you have stock rear suspension, where do you set your pre-load for riding stag and for riding two up? If you have bags or a tour-pack, please note that and the type.
Thanks,
Frank
I have mine set at "4" (I think..lol)....I prefer a bit firmer ride (and tighter handling) when riding solo, yet that gives the better half a nice cushy ride when she's riding shotgun...
Out of laziness/absentmindedness, I leave mine at 5 most of the time. I have no way to predict if Tina will want to ride with me and I usually forget to check/adjust them when she does.
A lot depends on what you weigh and how you ride. I weigh 192 and like to cruise, and not scrape my floorboards on curves. Roads are usually pretty smooth around where i live, except in Manhattan, or Brooklyn. I set mine on two, love the ride and i dont complain about my stock seat either. :D Bry
Mine live at 5 all the time. Saddle bags are mostly empty. Maybe 5lbs between them. But I'm pushing about 360, so its like many riding 2up.
while you're checking and setting, look at your shock bushings :hmm2:!
they may need to be replaced, give yourself a treat. you'd be surprised of the better handling you feel in the rear. just my $.02
i'm a light 235, ride it on 3, usually single (but dont get me talking on that, i may start to cry, and tell you about it...it all started when...)
no bags, weigh 215 and i have mine set to ONE and have never bottomed out. i like the softest setting bc the bike sits a little lower when riding and looks good and makes for a smooth ride, its great as long as you dont freak out when the floorboards drag!
Discussion Starter #10
If they're not leaking you'll be fine, that all you need to check. Just reset them both to the same setting.
I haven't noticed them leaking since I set them back. But like I said, they may have been like that for a few years....
If they aren't leaking, push the rear of the bike down and release it. If it doesn't bounce a few times before stopping the shocks are working.
Gator for life
I ran mine at 4 for a little while to try it, but went back to 3 for solo and 2 up riding. Nice ride both ways, and we go a total of about 400 when 2 up. I agree with Jerry, you are probably fine as long as they aren't leaking and are still performing well.
Dragging the boards just means your using the whole tire, to ensure even wear. There's one curve I drag nearly every pass. But I'm pushing a bit more than my grandpa would.
Discussion Starter #14
thanks
They seem fine, thanks for the tips on what to look for.
Regards,
Frank
No Reason To Be Serious
I run mine both at 5 all the time... sometimes I am retaining water, and just don't feel pretty, so I just keep 'em pumped up all the way ...:)
Thumper
At 235, I keep mine on 4. I ride solo and even at 4 I've bottomed out a couple times. I'm think about bumping them up because of that.
I keep mine on 5 but ride 2up a lot. You do want to look at the bushings though, mine were shot at 8000 miles and just replaced them with the nylon replacements from McMaster and Carr, what a difference in handling, makes the rear end very stable.
STEVE
1 - 17 of 17 Posts
