2006 Honda VTX 1300 R
Anybody know what the side covers are made of on a vtx 1300? I broke off the inside tab that hooks into the sleeve. I tried plastic glue but won't take.
Any suggestions on either a glue or epoxy that would bond instantly
They are plastic, exactly what type IDK. If Gorilla Glue doesn't hold it you are probably on a scavenger hunt for another one. The rubber grommets get hard, making pushing the flared stem into it very hard, and this is where many break off. I just replaced a 2014 Nissan Rogue right rear light bucket with one from a salvage yard, and one of the 3 flare-head pins it was made with was broken off. Luckily it will stay in place with the other 2 and the single body bolt. Plastic gets brittle the more it ages.
2007 1300C
Reactions: PaXman11
· From ID, GO VANDALS!
2005 VTX 1800N Spec 1
I have repaired a few plastic items lately with super glue an baking soda. There are a number of videos on you tube showing the results of this trick.
I fixed my daughters plastic glasses frame with this trick. Super glue wouldn't have held on its own, but somehow the baking soda sprinkled on there made them hold until she got her new glasses a couple weeks later. It also speeds up the dry time, it is almost instant once the baking soda hits the glue. Creates a very hard "weld" joint. It may not work in this instance, but what do you have to lose...
Ride Safe!
Reactions: PaXman11
· Faith Fears Not
MEK might weld it, if you do try MEK follow all safety and don't breath the fumes.
