Do you happen to have the wrong model bulb in the front indicators? My bike did this when I had it because the previous owner installed 1157 or 1156 (I dont know which it should be) instead of the other. This was front bulb was backfeeding the circuit leaving the cluster bulbs on when not flashing and the tail lights on as well (the front running lights were back feeding the circuit).I installed LED turn signals on the front only and having trouble with the flashing of the back two lights, both flash at the same time and also the indicators on the tank both stay on when not using the turn signal but both fash when one side or the other is turned on. Was told I don't need any diodes since I have dual turn signal indicators. What can I do ?
Ohm-meter connections
I have a 2002 1800c and everything on it is original. Though I only have nearing 17000 miles, all electrical stuff is considerably old. I also have a Suzuki C90 and those things are apparently having a lot of problems with the Regulator/Rectifier and the stator. I want to measure the amount of voltage coursing through my system when under a load in an effort to make a guess as to the current reliability of electrical components. So, should I make some preventive maintenance corrections before I wind up with a "quit" engine or battery while tooling through the toolies. While I am ta it, is there a special type ohm-meter for testing these systems or will any work as long as it measures DC current?
I have a 2002 VTX 1800 that the previous owner installed a rear brake light flasher also, the turn signals that I put on are aftermarket and are LED. I don't know if I need t change the flash unit or just get different turn signals.Do you happen to have the wrong model bulb in the front indicators? My bike did this when I had it because the previous owner installed 1157 or 1156 (I dont know which it should be) instead of the other. This was front bulb was backfeeding the circuit leaving the cluster bulbs on when not flashing and the tail lights on as well (the front running lights were back feeding the circuit).
Note, I have a 1300, so I do not know if this issue applies to the 1800, or if your LED issue relates.
There are aftermarket LED turn signals. Probably not the right ones.Do you happen to have the wrong model bulb in the front indicators? My bike did this when I had it because the previous owner installed 1157 or 1156 (I dont know which it should be) instead of the other. This was front bulb was backfeeding the circuit leaving the cluster bulbs on when not flashing and the tail lights on as well (the front running lights were back feeding the circuit).
Did the turn signals you replaced work correctly? Do you have a picture of the wiring diagram for the new LED signals? There are a lot of smart people on here. The more specific information you can provide, the more likely you will get a relevant answer.There are aftermarket LED turn signals. Probably not the right ones.
