1 - 3 of 3 Posts
was changing the plugs today and when I pulled on the boot the wire came out of the boot, pushed the wire back in, will this be ok. Also changed the air filter and in the bottom of the filter holder was about 2 oz of oil, is this a problem.
Plug wire is good just push on and then twist like you are screwing it together then get some dielectric grease for the plug boots it keeps moisture out and makes it easier to take off next time.
part of the maint is to drain that sludge from the crankcase breather line that builds up in the bottom of the box.
Boot screws onto wire...wire pushes into coil. Don't use any solvents (carb cleaner) in the throttle body. Just wipe out the oil with a clean, dry cloth.
1 - 3 of 3 Posts
