1 - 12 of 12 Posts
Just installed a new battery. Now the right blinker is blinking like crazy whenever I activate it and the left one is at its normal blinking pace. Before the new battery was installed, both were blinking at their normal calm rates. What's up with that? Why would a new battery cause this? Should I replace the bulb or just feed the right blinker some ritalin?
One of the bulbs burnt out...The decreased load on the system from a burnt out bulb makes the flash speed increase...Just a coincidence it happened when you changed the battery...
One more thing...When installing the new bulb, CAREFULLY note the orientation of the "tits" on the sides..It's possible to install the bulbs 180* out of phase and they still won't work right..Why Honda didn't "idiot proof" them like car bulb sockets is beyond me...When I installed my lightbar, it took alot of head scratching before I figured out what the problem was...
You could try switching the bulbs from left to right to see if it is the bulb. Watch out when you remove the lens of the turn signals. The turn signal housing has a delicate little plastic tab that can easily break. If it does, it cannot really be repaired and you have to replace the entire housing. To avoid breaking the tab first remove the screw on the bottom of the housing. Then squeeze the body of the turn signal housing together slightly from left to right. This elongates the opening in the housing where the lens fits. Then pull the bottom of the lens out slightly from the bottom of the housing. While still squeezing the housing, wiggle the lens as you pull further on the bottom of the lens. Eventually it will come out of the housing hopefully leaving the tab behind and intact.
G'day,
Vinish
Edit - Oops. While I was typing my note, you got better advice and implemented it. Glad it worked out to be a minor thing.
Discussion Starter · #6 ·
Rut-row Astro. Something's not working. The rear right blinker doesn't work. I tried oriented different ways like you said Bill. I looked at the working bulb on the left and matched that orientation. I even swapped the left and right bulbs.
It might be possible I knocked something loose when I installed the new battery. Anyone know which wires control the blinkers?
Discussion Starter · #8 ·
I love this place. I really do. Charlie, Bill, Vinish thank you very much. The blue wire leads were disconnected. All is well again in VTX land.
Dang!! How great is this forum? It is packed with great guys and terrific info. I am so freeking glad I found it.:cheers:
1 - 12 of 12 Posts
