1 - 4 of 4 Posts
Okay, so last week I had the seats and tank off my 2007 1300 R. Well the spedo works just fine, and the neutral light and engine oil lights work.
However, the lights for the turn signals, the high beam light, and the backlight for the spedo aren't working.
I have checked, rechecked, and checks the two green connectors. I did break the tabs on the green connectors which keep them tight, but they are really pushed together. Even when I have both pushed in as I squeeze them together the stuff doesn't work.
Any advice?
PS: I am no electrician.:banghead:
All wiring goes threw the two green plugs at the right front of the tank.
Check that they are connected all the way. There had been times in the past that the pins in the plugs get pushed back into the plug and don't make contact. Look closely -very closely. Your problem is at those plugs.
Donut/Doug:patriot:
Arggghhhhhhh
:banghead::banghead::banghead:
I ran all last year with my temp light on. It went off when I turned on my highbeams. This year during my deconstruction I noticed that the pins were bent and didn't make contact. My point is check out the green connectors well. Its easy to miss.
1 - 4 of 4 Posts
