21 - 23 of 23 Posts
There Can Only Be One
Just wondering, do any of these posts have to do with a "vibrating" needle? My speedo needle seems to move back and forth more than it should ( I think). It's not a steady movement as it moves when riding like my car. The needle is still as it changes speed. It doesn't seem like a huge deal. Just wondering if this a problem that will get worse or if its caused by the issues described here. I had the vibrating speedo housing years ago. I knew it cause when I pressed down on it with my left hand while moving, it would stop. It was very loud and annoying at first....till I got loud pipes! :)
Has your speedo faceplate been changed from the stock one?
No. Just tried putting some silicone caulk around where speedo meets housing. I'll see if that helps. If not I'll live with it
I need some help getting the vibration out of my tank mounted speedometer. I have put o-rings under screws, adjust mounting bracket at front of tank. I'm lost can't stand the vibration noise. Please HELP!
:confused: :confused: :confused:
I had the same problem, I purchased a silicone seal from ebay that goes around the speedometer and installed rubber washers under the cowling as well noise gone!!
21 - 23 of 23 Posts
