1 - 20 of 84 Posts
Lately there has been quite a bit of questions and comments about which HID and how to wire one. So after reading all the stuff here for the last several months, detailed below is the route that I went with.
I also ended up doing a step-by-step write up for those of us who need pictures and steps to assist us in the installation of pretty much any HID kit. They can’t be much different (the ones without the Hi/Low will not have the Hi/Low connections to worry about).
Bought my HID kit from DDM Tuning. It’s the H4 Hi/Low Kit. It’s the 55 watt as opposed to the 35 watt kit. Color is 5000k.
The 55 watt gives out more light. I could have gone with 6000k in 55 watt, but if you go with the 35 watt, you do want the 5000k, to get the most light.
DDM’s product is the least expensive kit out there with the added bonus of the hi/low option. They warranty the HID bulb and the ballast for life. They say that no one has reported any issues with the ballast powering up and out when starting the bike. If it burns out, they will replace it. There are other here on this site who have been using their kit for some time now without any side effects.
DDM’s service sucks. I called three times, and got pretty much people got three different people in their technical department that knew nothing. I got put on an indefinite hold the 2nd time, hence the reason for calling the 3rd time and after waiting 10 minutes, I hung up.
Please note: that DDM says that their warranty on their HID bulb, Ballast & the wiring harness is VOID if it is alter in any way!! This meant that I could not cut out the fuse and move it to another location. Also, I could not cut and extend the Hi/Low plug into the headlight bucket (solved this problem by using the plug on the shorter lead for the ballast-see below).
Before you begin the install, make sure you test out the kit while it is separated from the bike. Install the bulb into the headlight first, and connect the three prong switch into the headlight bucket then with it on your lap or on a stable surface, connect it to the battery and see if everything works. You don’t want to install it completely and find out that you have to pull it off to get warranty work done.
Steps you need to do to start first that are not explained here:
1. Remove the seats
2. Remove the tank
3. Partially remove the air breather box from the carb, don’t need to remove the lower hoses.
4. Remove and unplug the head light from the headlight bucket.
Here is a look at the kit I got (see pic below), No instructions, had to ask them to email it to me because I couldn’t down load them.
This gives you a closer look at the (2) wiring leads for the ballasts. Plug the longer lead into the ballast and the Hi/Low plug on that one in NOT USED. We will use the 2nd wiring lead (shorter of the two) for it Hi/Low plug only. See picture below. Please note when the wire from the ballast is routed to the bucket, the smaller black box will fall somewhere in between the neck and the bucket. This will be clear in a picture further down.
Note: in the next few steps, make sure you DO NOT TOUCH THE HID BULB WITH YOUR HANDS OR ANYTHING. You don’t want the HID bulb to burst on you when you plug it in.
:banghead: I completely forgot to take some additional pictures for the next few steps in removing the old halogen bulb and installing the HID bulb, but I got a shot of the final condition :)
Remove the rubber housing on the back of the head light bulb. Then unclip the metal clip, it rotates to you left and remove the bulb. Store the bulb away for future use when you HID goes out and a replacement is ordered.
Now remove the plastic case from around the bulb. Then remove the metal housing from the HID by hold the black part tightly and twisting the metal housing, and then pulling it off. Place the metal housing into the head case (it can only go in one way – there are prongs on there that will not allow it to be installed any other way). Place the pin over it and lock it in.
Now place the rubber boot over the metal housing. The inside round opening in the boot will go over the metal housing, not inside of it. The bulb has a rubber washer at the end that will seal that opening once the bulb is in place. I found that once I heated up the rubber boot, it installed on to the metal housing a lot simpler, otherwise you will be fighting it.
Once the boot is in place, install the HID bulb into the metal housing by sliding it in all the way and turning it. You can see that in the next three pictures. One is the HID bulb separated from its shield and case, one picture from the back side and the other of the front.
The next picture show where I placed the ballast and the Hi/Low module.
All of the wires were run on the right side of the bike. The following shows all the extra wires and length tucked into the free space in the neck.
Next picture shows where I snuck the Fuse Box for the HID to take to the left side of the bike.
The next picture shows where the fuse for the HID ended up being located for easy access at the cost of forfeiting the all warranty rights to this product.
The Next image shows where the positive and negative wires were routed to under the seat area.
Connect your positive to the battery. They have it all set up, so why not since I was using their inline fuse anyways.
Connect the negative to a ground post like I did or connect it to the battery ground terminal.
Note: when you are routing the wire from the ballast to the headlight bucket, the small black box will end up in between the neck and the headlight bucket. I have a 2.5” headlight extension on my bike, maybe that is why it ended up there.
The next image shows the plugs handing in the bucket for connection. You have the shorter ballast lead (only going to use the Hi/Low plug on that lead), the positive and negative connection to the HID bulb. Lastly, the three prong plug.
Connect the three prong plug into the socket that you pulled from the halogen bulb.
Now connect all three lead from the HID bulb to the remaining three connections.
You are now done wiring your HID!!
Just put the headlight back on, the tank back into place and install the seats and you are ready to test out your new HID.
Since I still need to work on the flange bearings, I don’t have a picture with them on at night on the road, but it will soon follow and I will post it here.
Sorry for being picture intensive, but that is what I like to see and is helpful for me. If I forgot something or something needs to be added or you have any other advice or comments, feel free to post them too…..
Ride Safe and be seen !!
thanks jeff, you know you opened up my road on electrical wiring, so here it is being put to use....
big jojo, i would buy. like i said the product is good, it is really inexpensive when compared to the stuff that is out there, full lifetime warranty.....its just my customer experience when trying to ask some few basic q's, they were poor at that. i would still buy from them. they deal with high end cars and items.....so they must know their stuff, or at least the top end guys..
· Senior Member
Fantastic write up, thanks for taking the time to post, I'm sure it was time consuming. :cheers:
· GOT PITBULL?
Ok, thanks. It seems more and more companies are letting their customer service go down the toilet... I mean everything from restaurants to pool services to auto dealerships. I own 2 buisnesses so I know with the economy the way it is people are trying to get the most for their money and as a company you have to make the feel good that they're spending their money with you but a lot of these companies don't seem to understand that.
How does the high/low function work? Last I heard a single HID bulb couldn't do both. I must be really behind the times!
Discussion Starter · #9 ·
thanks kenko! it was time consuming, but i actually enjoyed it
the bulb actually tilts up and back for hi/low. i wanted to take a picture of it on the road, but i am taking my flange to a machine shop monday, so i couldnt check get the bike on the road as of yet. however, i am curious as to how different it is.
in the garage right now, the center portion of the beam moves up and back when i cycle through the hi/low poisitions.
Discussion Starter · #11 ·
ok, i am sorry it took so long to get the pics to you guy, but it just took forever to get my bike on the road, so here are the results of the HIDs that i put on my bike, enjoy as promised:
HIDs WITHOUT MY DRIVING LIGHTS:
HIDs WITH MY DRIVING LIGHTS:
Discussion Starter · #12 ·
adjusting the headlight up and down
i've got some guys riding opposite to me at night on a two lane road signal their high beam. so that means my light is hitting where it shouldnt.
how do i adjust the headlight up and down? i tried the two screws at the bottom, didnt seem to move the beam any closer to the bike...
any ideas?
thanks!
· Cafe Vendor
Discussion Starter · #14 ·
thanks jeff for the info! let try that and will post the results...
Discussion Starter · #15 ·
jeff, that thread proved to be very useful!! just got done readjusting the headlight!
· Cafe Founder & VTX lover
I got my kit in and I'm trying to install it now...unless I'm missing something there is no way the connector to the old headlight plug and the + battery are long enough.
As stated this come with ZERO instructions...I did find them online and download, I have attached it to this thread. So, did any of you have to add more length to the + cable so it would reach to the battery?
Well I had to cut the + wire and add some length to it to make it work, no way around it. Got it all wire up and it's working great, just need to get the tank and stuff back on.
I think the kit has changed since the first post by Omar...the wires from the DDM module were very short, no way would they go from where I had it mounted to extending outside the headlight bucket. I had to have my wife hold the headlight assembly up to the bucket just to get the wires to reach.
I cut the + wire between the module and the fuse and added about 10" to reach the battery, after that no problem. I highly suggest testing the light before putting everything back together.
Here where I mounted my stuff.
Discussion Starter · #19 ·
sorry big x, i have not been here for a while and did not see your question. you are correct about cutting the positive wire and adding a length in there. some one a while back had pm'd me and they had to do the same....but then just recently some one was has problem with the grounding, he didnt need to extend the positive wire.
so my guess is that they just grab what ever wiring kit they have available and just send it out.
1 - 20 of 84 Posts
